Report Filtering: cbQl, Omit certain fields
I have a requirements tracker that has two specific fields I want to create a report based on. Once Choice field (1) Software Related with Options: Yes or No. Second Choice field (2) Devices with Options: Device1, Device 2, Device 3.. etc. It is a choice field allowing multiple options selected. In my report I want to List the requirements with Choice Field Software Related = Yes, Group By Devices but omit device 4 from the list. Is this Possible
6-Contributor
Yes, you should be able to make a report for this. First select the project and tracker which has the fields you want to filter. Then in the add filters section, choose your first choice field (software Related) from the list of options. It should pop up with a window where you can chose "Yes". Next add a second filter for choice field 2 (Devices with Options). It should pop up with a window where you can choose (Device 1, Device 2, and Device 3), leave Device 4 unchecked. Then click go and you should have your report.
Ive done this, but when you use group by that same field, it will include device 4 in my report which I dont want to include
