Brian Kampling
Jul 22, 2025 4:08 PM UTC
Reports with multiple baselines
I have a report where I am using the historical view to show trackers at a specific baseline. Currently, I have only been able to display one baseline at a time. Is there a way to show multiple baselines in the same report?
Brian Kampling - Source Allies
pshashipreetham
Jul 24, 2025 2:37 PM UTC
As of the current Codebeamer capabilities, the Historical View in reports supports only one baseline (or one point in history) per tracker configuration at a time. There's no native support for overlaying or comparing multiple baselines within the same report view.
However, here are a few workarounds:
  1. Duplicate the Report Section:
    Create multiple report widgets (or sections) side by side or vertically, each configured to a different baseline. Although not in a single unified table, it provides a visual comparison on the same report page.
  2. Custom Scripted Report / Export:
    Use the REST API to fetch data from multiple baselines and aggregate externally (e.g., via Excel, Power BI, or a custom app). This allows side-by-side comparison or delta reporting.
  3. Snapshot Compare:
    For specific comparisons, consider using the Tracker → Compare Baselines feature, which highlights differences between two baselines, though it isn’t embedded in a report.
Unfortunately, there’s no built-in feature (as of 3.x) that allows multiple baselines to be rendered together in one dynamic grid inside a report.
Hope this helps.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
pshashipreetham
Hope this helps.
Geoffrey Clemm
Jul 24, 2025 3:29 PM UTC
It would be interesting to know why would want to compare more than two baselines, and what you were expecting to see in the multi-baseline compare.
Brian Kampling
Jul 25, 2025 4:29 PM UTC
Hi @GeoffreyClemm
I wish I could share more, but because of the sensitive nature of the client/project, I can't go into detail here.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
