Rest API permissions for Codebeamer trial version
I'm using Codebeamer  trial version to check API behaviors.
I'm able to test it on the API tester.
However, if I copy and paste the Curl commands from above and run the same from the terminal, I get the following error.
Is there a way to get API permissions for the trial version?
{"message":"User .... [....] doesn't have Rest/Remote API - access permission.","resourceUri":"/"}%
alfonso_cAnswer
Hello @HN_11561867 , on the https://trial.codebeamer.com/ page, there is a button at the top-left corner:
That should take you to this page: https://www.ptc.com/en/contact-us
Please fill in the form to contact the PTC Sales Team, your request will be assessed.
Thanks very much for your time and cooperation.
Community Moderator
September 10, 2024
Hi @HN_11561867,
Thank you for your question.
Vivek N
Community Moderation Team.
alfonso_c14-AlexandriteAnswer
