Mar 11, 2025 7:00 PM UTC
Retrieve a tracker of a given baseline via Restful API?
As shown in CodeBeamer documents, baselines can be created for a project or a tracker.
When we retrieve a tracker using Restful API, can we specify a baseline then? The document for Restful API shows nothing related to baseline. Did I miss something here please?
7-Bedrock
Apr 8, 2025 6:24 PM UTC
From the Swagger ( `/v3/swagger/editor.spr` on a Codebeamer instance) there is an option for specifying baselines on a specific tracker item but not as part of the item search.
`/v3/trackers/{trackerId}/items` will return all the items for a tracker but does not appear to have a way to specify a baseline to be looking at.
`/v3/trackers/{trackerId}/baselines` will return the baselines that involve the tracker you are looking at.
`/v3/items/{itemId}` has a query parameter for baselineId documented which will return a 404 status if the item does not exist on that baseline or the details of the item if it does.
Example URL for the GET call would be:
/api/v3/items/6669?baselineId=39338
With "6669" being the item ID.
Community Moderator
Apr 20, 2025 7:09 PM UTC
Hi @RR_12247123,
Anurag
