Support at Codebeamer how can move a git repository from a project to another
how can i move a git repository from one project to another? unfortunately i can't find any help in the codebeamer help center.
Try to ask here - "Codebeamer User Group": https://community.ptc.com/t5/Codebeamer-User-Group/cmp-p/grouphub:codebeamergroup
Now I found a way to move git repo with the same name between 2  codebeamer projects:
  1. create bundle by git bundle create dmp.bundle --all
    1. be sure that all branches are checkout locally otherwise they are not in bundle (you may need to write a script)
    2. make tests that the bundle contains everything
  2. in CodeBeamer you need administration permission
    1. got to current project
      1. delete the current git repo
      2. clean up the trash
    2. on filesystem of Codebeamer delete (rename) the current git repo
    3. got to new project
      1. create new repo with indication of created dmp.bundle and the same repo name
  3. clone repo for testing
Good luck!
