Test Case Status Not Retained After Copy
When a Test Case tracker is created using template inheritance, the option
“Make a copy of the items and link the target item with the copies” is not consistently available, and copied test cases do not retain their original status.
This behavior is observed while copying test cases from a base Test Case tracker to a template‑inherited Test Case tracker
The copy option “Make a copy of the items and link the target item with the copies” is not displayed.
Test cases copied via drag‑and‑drop are created with status = Draft, even if the original test case is in another status (e.g., Approved).
Please refer case details Case Details - 18070485 for more information
Catalina
Community Manager
Hi ​@SY_10545985
Thank you for your post!
Please know that you make a reference to a case number but users will not have access to it and won't be able to get the insights you intend. If you need to share information from the case with other users here, please make sure not to include any proprietary and/or sensitive data,a s this is a public space.
Best regards,
Catalina | PTC Community Manager
Brian Kampling
​@SY_10545985 this configuration is by design to protect the integrity of test cases. This prevents someone from creating a test case and bypassing the approval process. If you would like to modify this behavior, you can change the State Transition workflow settings in the tracker config.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
Hello ​@BKampling_SAI ,
Thank you for providing the information.
Could you please guide us on the exact workflow configuration that needs to be modified to achieve this requirement?
If possible, could you also share any documentation or reference material related to this configuration? It would help us better understand and implement the required changes.
Brian Kampling
Hi ​@SY_10545985
Without knowing your current workflow configuration I won’t be able to give you the exact workflow configuration. Here is the official documentation that should help: https://support.ptc.com/help/codebeamer/r3.2/en/index.html#page/codebeamer/user_guide/816604.html#
If you have specific questions I might be able to help you as well.
