Oct 17, 2024 7:12 AM UTC
Upgrading from Codebeamer 22.10-SP7 to Codebeamer 2
We are going update Codebeamer from 22.10-SP7 to Codebeamer 2. Do you have some ideas or walkthrough how to do that, because I can't find any information.
Thanks in advance
GVajdaAnswer
Oct 17, 2024 8:00 AM UTC
You can find the tested upgrade path document here: https://www.ptc.com/en/support/article/CS400089
Please also check the prerequisite requirements in Codebeamer release matrix pages here: https://support.ptc.com/cs/release-calendar/index.html
It is wise to do the upgrade first on your test instance.
GVajda14-AlexandriteAnswer
Oct 17, 2024 9:10 AM UTC
Thank you for this information. I will read carefully upgrade path and will tell the results after upgrade
