rattmice
Jan 5, 2026 2:58 PM UTC
Viewing the CAD Part in the DPT integration
I have CB 3.1.0.1 integrated with WC 13.2.1 via the DPT integration and from CB I can click on the linked part to see information about it but I don't have the Creo View widget.  Am I missing something in the configuration for this to be enabled or perhaps an additional extension to install?
rattmice
rattmiceAnswer
Jan 13, 2026 11:01 AM UTC
This is controlled by the PreviewConfig.basicPreview setting in the application configuration.  When this is set to true you get a limited view of the Windchill data.  Setting to false solved the issue.  This setting does not appear to be present in Codebeamer 3.2.
"PreviewConfig": {
 "basicPreview": true,
 "height": 550,
 "width": 710
Catalina
Community Manager
Jan 13, 2026 9:03 AM UTC
Hi @rattmice
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
rattmice
rattmice14-AlexandriteAuthorAnswer
"PreviewConfig": {
 "height": 550,
 "width": 710
