May 12, 2025 1:38 PM UTC
when executing a Custom script for Tracker item attributes are modified and saved facing error
Error:
Transaction aborted; nested exception is java.util.concurrent.ExecutionException: org.codehaus.groovy.control.MultipleCompilationErrorsException: Execute a custom script: startup failed: Script7.groovy: 5: unable to resolve class com.intland.codebeamer.event.ItemChangeEvent @ line 5, column 1. import com.intland.codebeamer.event.ItemChangeEvent ^ Script7.groovy: 7: unable to resolve class com.intland.codebeamer.manager.NotificationManager @ line 7, column 1. import com.intland.codebeamer.manager.NotificationManager ^ 2 errors : Script7.groovy: 5: unable to resolve class com.intland.codebeamer.event.ItemChangeEvent @ line 5, column 1. import com.intland.codebeamer.event.ItemChangeEvent ^ Script7.groovy: 7: unable to resolve class com.intland.codebeamer.manager.NotificationManager @ line 7, column 1. import com.intland.codebeamer.manager.NotificationManager ^ 2 errors
Catalina
Community Manager
May 21, 2025 7:28 AM UTC
Hi @Rubiya
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Where and how are you executing this custom script within Codebeamer (e.g., workflow action, trigger, manual execution)?
  • Are the required classes (ItemChangeEvent, NotificationManager) available in your current Codebeamer version and scripting environment?
  • Is this script based on an official example or custom-developed? If custom, has it worked in previous versions or environments?
Please add screenshot(s) to better understand what you are trying to do in your process.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
