Apr 23, 2025 7:40 AM UTC
Word Export for Test Run tracker Exception in thread "main"
Hello all,
trying to Word export for test run tracker but get below error:
com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxMergeFieldExporter$ExportAppError: Error inside export application: Exception in thread "main" java.lang.reflect.InvocationTargetException
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.checkIfAnyExceptionOrError(DocxJvmExportManager.java:197)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.checkForErrors(DocxJvmExportManager.java:172)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.checkForErrors(DocxJvmExportManager.java:166)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.runJvmExportProcess(DocxJvmExportManager.java:149)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.lambda$runJvmDocxExport$0(DocxJvmExportManager.java:85)
	at com.intland.codebeamer.flow.form.ParallelProcessGuard.execute(ParallelProcessGuard.java:42)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.runJvmDocxExport(DocxJvmExportManager.java:80)
	at com.intland.codebeamer.controller.importexport.export.job.ExportJob.convertToDocx(ExportJob.java:177)
	at com.intland.codebeamer.controller.importexport.export.job.ExportJob.doExecute(ExportJob.java:117)
	at com.intland.codebeamer.utils.scheduler.StopWatchJob.execute(StopWatchJob.java:66)
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202)
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)
Found similar topic in knowledge base where  suggested solution is:
  • Check if there are any deleted working sets recently.
  • If it is possible, restore these working sets and then perform the export again.
See below link:
https://www.ptc.com/en/support/article/CS424822?source=search&as=1
I don't know how to identify deleted working sets.
I am not an owner of tracker and only support user in his issue.
Maybe there is also another fix.
Codebeamer version 2.0.0.5
thank you
Catalina
Community Manager
Apr 29, 2025 2:44 PM UTC
Hi @MM_10991077
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
