Word Template "Codebeamer Advanced Congiguration"
Hi I'm started with the Codebeamer Advanced Congiguration in the PTC Demo environment.
I'm running into the issue that the parameters template document is not available in both "the Demo environment" as the "Codebeamer Advanced Configuration training material"
Has anybody idea where i am able to find the  document?
pshashipreetham
That document is not included directly inside the demo environment. In the training material, the “parameters template” Word file is usually provided separately as part of the Codebeamer Advanced Configuration training package, not inside the project itself.
Two places to check:
  1. In the PTC Learning Connector / training download section for the course. The Word template is typically included in the downloadable exercise files for the training.
  2. Inside the demo project under Documents or Wiki attachments. In some demo setups the template is attached to the training instructions page rather than exposed as a standalone file.
If neither location contains the template, it usually means the exercise files were not imported into the demo environment, and the easiest option is to download the training package again from the course resources.
Thanks.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
jw_CS14-AlexandriteAuthor
The training assumes that i login on a dedicated PTC Training environment. But as PTC Parner i have access to the Partner VM's. In the Partner VM's there are a few example projects, but this kind of additional information is missing.
Brian Kampling
​@jw_CS you could export the training material from the PTC Training environment and then email it to yourself from within the PTC VM and then import it into the desired environment. Just double check that this doesn’t violate any terms or conditions for Field Academy use.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
