1/4 revolved model
I am fairly new at Mechanica, so bear with me. I am doing a static analysis
using a 1/4 revolved model, for faster processing. If the total force
applied is 10N do I need to cut the force in 1/4 (2.5N)?
Sara
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
    MessageSara,
    That is correct, as long as your force is expressed in terms of Total Force, and not Force per Unit Area/Length.
    Good luck!
    Randy Speed
    President and CEO
    Speed Consulting, LLC
    (972) 938-0490 ph (972) 937-2319 fax
    www.speedconsulting.com
