3D text and solid bend
Gurus of the solid bend; or in PTC speak, bend solid,
One of my work colleagues is having a problem and I don't know what the
answer is. He has some text on a flattened quilt which he will be
transferring to the solid body as a cut out. To this end he has a sketch
of the text extruded both sides of the quilt. However, when he performs
the solid bend, for some reason the text is flipping so the letters are
mirrored - fine for Leonardo but not what our customer wants. This is
not something that he and I have never seen nor can we find the
reason/solution. Has anybody seen this before?
Richard A. Black
Lead Engineer
Eaton Corporation
16900 Aberdeen Road
Laurinburg, NC. 28353
Tel: 910-610-1788
Fax: 910-277-3700
    Richard,
    I would make sure that my text sketch is fully constrained (i.e. no assumptions). Also, I have see weird stuff like this occur with sheetmetal. Are you using the sheetmetal module?
    Sincerely,
    Neal Rosenblum
    Geometrix Engineering, Inc.
    201 N. 13th Avenue
    Hollywood, FL 33019
    Ph: 954-920-2049
    Fax: 954-920-9574
    Cell: 954-649-9399
    <u>neal@geometrixeng.c</u>
