Jan 28, 2015 1:13 PM UTC
3D Text size in Creo2
Hi all,
I've started dabbling with 3D annotations & notes with a view to going paperless in the near future. One thing I'm wrestling with is the varying style, notes are different to dimensions, but also neither are to any pre-defined text size or font etc. Is there anyway that you can set the default text style so that all 3D annotations appear the same when created?
Ian
    2-Explorer
    Jan 28, 2015 3:00 PM UTC
    In Creo 2, models now have "drawing properties" as well as model properties. Go to File > Prepare > Model Properties > Detail Options. The dialog that opens is similar to drawing detail options; I think the property you need is text_height.
    ptc-500331-VisitorAuthor
    Jan 28, 2015 3:17 PM UTC
    That's great, thank you. Yes text height in here was set to 'CALCULATED'
    I've also just noticed that you can point you config to a 'Drawing_setup_file' using:
    MODEL_DETAIL_OPTIONS_FILE
    Not tried this yet, but hopefully it works.
    Thanks again.
