Jun 12, 2013 6:32 PM UTC
3DConnexion ergonomics
I've been looking at the 3DConnexion range recently. It comes down to the SpaceNavigator or the SpaceMouse Pro. The SpaceMouse is marketed as the more ergonomic product because it has a wrist support.
I know enough about wrists to know that products which put your wrist flat on the table aren't very ergonomic. I am lead to believe that the cheaper SpaceNavigator would be the superior product since it looks like it could be used with a vertical wrist position.
If anyone uses ergonomic HID devices and has used 3DConnexion products, please could you share your experience?
Thank you
    Jun 12, 2013 6:44 PM UTC
    I have the spacenavigator and you are right; your wrist is not resting on the table.
    Jun 12, 2013 6:59 PM UTC
    I have the older Space Explorer. The ergonomics work extremely well for me. The button placement takes a little time to get used to. The ALT, SHIFT and CTRL buttons are huge bonuses. It is very similar to the Space Mouse Pro.
    I've also used the Space Navigator. It does allow me better control over my models and quicker manipulation. I don't like the ergonomics. It always makes my hand feel cramped, kind of like using a really small travel mouse. The fact that it is easy to pick up, really annoys me.
    Jun 12, 2013 7:05 PM UTC
    Which Space Navigator did you use, Josh? They have one for notebooks which is smaller and lighter. I use the original which is much bigger than a travel mouse.
    I even emailed 3D-Connexion about the notebook version and the reply was quite forthcoming about the travel version being too light at half the weight of the original.
    Jun 12, 2013 7:32 PM UTC
    I use the larger version with wrist pad and buttons.
    The travel one is the version that I really didn't like. It was still better than mouse-only.
    David_M1-VisitorAuthor
    Jun 12, 2013 7:37 PM UTC
    I should clarify that my concern is with the horizontal wrist position which it seems like the SpaceMouse encourages. The absence of a wrist support on the SpaceNavigaor seems to be preferable as it might accomodate a vertical wrist position.
    Jun 12, 2013 8:38 PM UTC
    I'd say the SpaceNav is the middle of the two examples.
    This is pretty accurate to how it fits me:
    http://ecx.images-amazon.com/images/I/41fJCGBcODL._SX385_.jpg
    Jun 12, 2013 8:51 PM UTC
    The older Space Explorer is the one I have with the wrist pad. It's difficult to show, but my palm rests on the rubber pad at the base. My palm probably rests at about a 30 degree angle naturally. Overall, it feels very comfortable. Sometimes the buttons are a little goofy to reach though. I haven't tried the sideways "Good wrist position".
    The "travel" space navigator is shown below. The position is just awkward to me. I have felt irritation in my wrist with this device.
