Adding a parameter to a model
Hi all, I'm adding a parameter to my model, I name it, set it to a YES_NO, enter the value (as yes), but can somebody please tell me what the "designate" tick box is all about. Thanks.
    Ian The "Designated" checkbox indicates if the parameter value should be copied to/from a PDM system during checkin/checkout. If you are not using a file vaulting system like Intralink or PDMLink this checkbox is not really relevant for you and should be left unchecked. Hugo
