Adding a Parameter to to Hole table
I have a request to start showing oversized pitch diameter for tapped holes. I have tried adding a parameter in the UNC.hol file without much luck.
Any help or suggestions are greatly appreciated.
David
    Without seeing your .hol file and parameter I would say that you maybe you are not restarting Pro-E after each change. That file is loaded during startup and therefore changes made to it must be done with a restart. Maybe this is not the case and you are restarting, with that I would have to see the file.
    Eric
