Jul 31, 2013 10:08 PM UTC
aligned dims not staying that way
I selected two dims and made them aligned.
[cid:image001.png@01CE8DFF.CC900310]
I then drag selected both, and selected between the arrows on the right dim and dragged them up and down.
[cid:image002.png@01CE8DFF.CC900310]
As you can see, they are no longer aligned.
Creo 2.0-m060. This didn't happen in WF4, they would stay aligned when you moved them.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
    MikePhillips
    Aug 1, 2013 1:40 PM UTC
    Hi David,
    I just confirmed the same behavior exists in Creo 2.0 M050. It appears, at
    least in my case, that the two do not become misaligned if I move the
    dimensions by selecting on the dimension value itself. They only become
    misaligned when I select the line of the dimension arrow. Good catch...I
    hadn't noticed this until now.
    Mike Phillips
    Raytheon Company
    This message contains information that may be confidential and privileged.
    Unless you are the addressee (or authorized to receive mail for the
    addressee), you should not use, copy or disclose to anyone this message or
    any information contained in this message. If you have received this
    message in error, please so advise the sender by reply e-mail and delete
    this message. Thank you for your cooperation.
