Oct 8, 2004 8:19 PM UTC
And another thing about Insert here...
Don't you think it would be easier if there was a pick in the RMB menu
when your mouse is in the model tree? 5 picks to do something that is
fairly common practice when you are examining someone else's model seems a
no-brainer to move it to the RMB menu.
Thanks again,
Brian S. Lynn
CAD Administrator/Designer
    Oct 8, 2004 8:40 PM UTC
    Well, sure - but that would be inconsistent with the Wildfire philosophy...
    Oct 11, 2004 1:16 PM UTC
    I've never said I lost functionality; however, most things that have changed
    take an average of about a third more mouse picks and lots of moving the
    cursor around the screen than they did before WF. At the end of a day of
    intense modeling, and especially detailing, I have hand cramps. Oh, and
    there actually is at least one bit of lost functionality - the detail module
    is no longer WYSIWYG - the axes on the screen no longer match what prints
    out. This is a HUGE step backwards, IMNSHO.
    Oct 11, 2004 1:30 PM UTC
    Another way to apply the insert function while in the model tree:
    Oct 11, 2004 2:52 PM UTC
    Carol you hit it on the head !!! I couldn't have said it better myself. The
    "reduced screen picking in wildfire, has been compared to all know cad systems
    and a 30% reduction is realized by making the switch to wildfire " This is a
    direct quote for Dan Campbell at PTC the statement was made at the Atlanta Pro-E
    conference 2 years ago. Dan if you are listening, sorry friend you are just
    plain wrong. Example #1 why does it take 3 to 4 cancel operations to get out of
    the wildfire sketcher as compared to 2 in 2001. This is a huge pain in the
    butt !!! I have numerous examples but in general I have seen the mouse picks
    go up at least by 1 pick... Not the reduction that Mr. Campbell of PTC
    marketing promised !!!
    H A R R I S C O R P O R A T I O N
    Government Communications
    Systems Division
    HARRIS
    Post Office Box 37
    Mail Stop
    102-9863
    Melbourne
    FL USA
    32902-0037
    Brian L. Taylor Phone: (321) 729-3781
    ElectroMechanical Designer II Fax: (321) 729-3899
    Radar 1A and 1B E-mail:
    F35 Joint Strike Fighter
    Assured Communications <http: www.harris.com="/> www.harris.com
    This information is only intended for the use of the individual or entity named
    in this email. If you are not the intended recipient, you are hereby notified
    that any disclosure, copying, distribution, or use of the contents of this
    information is strictly prohibited. If you have received this email in error,
    please notify me and delete it immediately.
    Oct 11, 2004 3:26 PM UTC
    >> in the butt !!!
    I always expect someone to respond "why do you need to cancel out of a
    sketch ?". 🙂
    Nonetheless, it happens to me a lot and I searched and found this mapkey:
    Oct 12, 2004 9:29 AM UTC
    But even if a 30% reduction is fact it STILL gives you 50% more mouse clicks
    than almost any other CAD system! 😉
    Oct 12, 2004 10:12 AM UTC
    I believe this is what you should all be referring to in your attempt to
    discredit Pro|E Wildfire as an improvement over previous versions.
