Mar 17, 2015 3:30 PM UTC
Annotating in 3.0
Are there any documents out there to show us what to do with the changes that where made? Dimensioning should not be this hard?
    2-Explorer
    Mar 18, 2015 6:31 PM UTC
    Hello Michael,
    can you provide a little more details? Are you referring to Creo Parametric 3.0?
    The community subgroup you started the thread in, is Rendering, but I assume this is rather about detail mode (drawing or 3D detailing), and therefore belongs to the general PTC Creo forum, right?
    Gunter
    Mar 18, 2015 11:03 PM UTC
    Detailing in general in Creo 3 should have optionally preserved the Creo 2 interface.
    I am completely astounded as to how anyone could have thought this was better for people who already knew how to use Pro|E.
    It is now a lot more work and nothing new to show for it.
    2-Explorer
    Mar 27, 2015 10:33 AM UTC
    I believe the only significant change is that the selection of a second reference requires the CTRL key to be pressed.
    For once this generates consistency with general functionality in Creo.
    And second it allows to easily deselect references, if you change your mind or picked a wrong edge - previously you had to use RMB > Dimension - New References and start again selecting.
    And obviously for better assistance, the dimension as it would look like, is displayed as a ghost before you place it - but this does not affect the workflow.
    Instead of a document, there is a tutorial video: Tutorial: Creating Driven Dimensions
