ANSI / ASME
Apologize in advance for asking such a stupid question but I read the
following link and I'm a bit confused:
    That article is somewhat misleading. ASME y14.100 has a section of
    statements that say stuff like..."drawing format requirements per
    ASMEY14.1" It has about 50 of such statements that basically point at
    the other ASME standards relating to drafting. So now you can put one
    statement on your drawing that says "Drawing Interpretation per
    ASMEY14.100." and you will encompass all of the different standards.
    (That is with the exception of y14.5 which has to be called out in a
    separate statement that includes the revision year. But that's another
    discussion.)
    Long story short: Y14.100 does not replace the other standards it just
    points to 'em.
    Cheers,
    John Suyes
    Propulsion Engineer
    Blue Origin, LLC
    21218 76th Avenue South
    Kent, WA 98032-2442
    jsuyes@blue.aero
    (253)-437-9311 desk
    (253)-437-9300 main
    (253)-437-9301 fax
    Thanks all. I'm now on the path to enlightenment...
    You are confusing the organizations & the standards. None of these are
    ANSI standards. Y14.5M is an ASME standard, it governs dimensioning and
    tolerancing. Y14.100 governs detail items in drawings, e.g., thread
    representation, letters allowed for detail views, etc
    No, it means that 14.5 is referenced in 14.100.
    ASME Y14.5M-1994 (R2004) / Dimensioning and Tolerancing and ASME
    Y14.100-2004 / Engineering Drawing Practices are still two different
    animals.
    ASME overtook many ANSI and DOD/MIL standards ...
    I for one, fell much better now....in fact...harmonious.
    discussion.)
    standards it just points to 'em.
