Jun 12, 2014 9:05 AM UTC
Any how (like macro) to repeat last command?
Hello All,
Is it there any command or any way to (like macro) to repeat last command?
Please help.
Manish
Jun 12, 2014 9:16 AM UTC
mgupta-41-VisitorAuthor
Jun 12, 2014 10:57 AM UTC
Dear Marco,
Attached site has some unexpected error ,showing on my system.
Manish
Jun 12, 2014 1:11 PM UTC
Manish,
try this one http://communities.ptc.com/ideas/2337
Martin Hanak
Jun 12, 2014 10:41 PM UTC
When you finish a feature, the feature keeps selected in the modeltree. What I usually do is copy paste with Ctrl+C and Ctrl+V. It´s pretty fast and intuitive for me.
I only have a mapkey for paste special since there´s no straight shortcut.
You can make a mapkey for that if you want:
mapkey \ ~ Command `ProCmdEditCopy` ;~ Command `ProCmdEditPaste`;
Another option is to use the find tool to select the last feature and copy paste it:
mapkey q @MAPKEY_NAMERepeat with find;@MAPKEY_LABELRepeat;\
mapkey(continued) ~ Command `ProCmdMdlTreeSearch` ;~ Open `selspecdlg0` `SelOptionRadio`;\
mapkey(continued) ~ Close `selspecdlg0` `SelOptionRadio`;\
mapkey(continued) ~ Select `selspecdlg0` `SelOptionRadio` 1 `Feature`;\
mapkey(continued) ~ Open `selspecdlg0` `LookByOptionMenu`;\
mapkey(continued) ~ Close `selspecdlg0` `LookByOptionMenu`;\
mapkey(continued) ~ Select `selspecdlg0` `LookByOptionMenu` 1 `Feature`;\
mapkey(continued) ~ Select `selspecdlg0` `RuleTab` 1 `Misc`;\
mapkey(continued) ~ Select `selspecdlg0` `RuleTypes` 1 `Last Feat`;\
mapkey(continued) ~ Activate `selspecdlg0` `EvaluateBtn`;~ Activate `selspecdlg0` `ApplyBtn`;\
mapkey(continued) ~ Activate `selspecdlg0` `CancelButton`;~ Command `ProCmdEditCopy` ;\
mapkey(continued) ~ Command `ProCmdEditPaste`;
And no, I think you can´t use the space bar for mapkeys
Jose
Jul 11, 2014 4:11 AM UTC
hello Jose,
Sorry for the late reply.
I tried the text file copy it and then paste at the mapkey OS script ,but its not working.
Please help.
Manish
Jul 11, 2014 7:50 AM UTC
You have to paste it into your Config.pro and reload it or restart Creo.
Jose
Jun 20, 2014 11:21 PM UTC
Hi Manish,
Let us know if you are still working on this or mark one of the user posts as "Correct Answer" if applicable.
Jul 11, 2014 4:12 AM UTC
Hello Clint ,
I am still searching for something to repeat last command.
Manish
Emeritus
Aug 13, 2014 1:18 PM UTC
Good day Manish,
Have you been able to resolve your issue?
Please indicate if one of the suggestions above helped you or if you solved things another way.
Best,
Toby
