Dec 19, 2011 7:54 PM UTC
Approximate Curve in a Skeleton Model?
I can't seem to create an approximate curve in my skeleton model. Is this a limitation imposed by PTC? Any suggestions of how to work around this?
Cheers!
    Dec 19, 2011 8:06 PM UTC
    My IT has me stuck in WF3, but no problems with the approximate. Are you doing a copy paste approx or sketching a curve and converting to spline? Either way, I would look at your curve segments to see if there is a break in tangency somewhere.
    Patrick Fariello
    lkerila1-VisitorAuthor
    Dec 19, 2011 8:10 PM UTC
    I'm trying to do this by copying several cuves and pasting as a single approximate curve (selection filter on geometry/copy items/paste items/choose approximate). I can do it no problem in a non-skeleton model.
    What's the other technique you refer to?
    Cheers!
    Dec 19, 2011 8:25 PM UTC
    The other way if you only need a 2D curve is to create the approx curve is sketch mode. Highlight the sketched segments, edit>convert to > spline.
    I am still guess that your curves have a break in tangency somewhere. If your curves are not at least tangent the appox curve is not an option.
    A few tests,
    1. Can you select just one of the curve segments, ctrl+C, ctrl+v, choose approx?
    2. Step this thru by added one more segment at a time to find where the non tangency or break is?
    Patrick Fariello
