TomU
Nov 18, 2014 12:12 AM UTC
Assign double quote character to a string parameter
Does anyone know of a way to assign a double quote to a string parameter via relations? I can manually create a new parameter and add a double quote to it, but not programmatically.
My current workaround is to manually create a parameter with a value of " and then use this parameter any time I need a double quote character.
DBL_QUOTE = " (manually created - doesn't work in a relation)
STRING_PARAM = DBL_QUOTE + "BLAH BLAH BLAH" + DBL_QUOTE
Yes, I NEED the double quote in the final string. The ASCII value (34) is critical.
Thanks!
Tom U.
    Nov 18, 2014 3:05 AM UTC
    Tom,
    Try the following. ...
    Parameter A = " + parameter B + "
    Hope this helps
    Don Anderson
    TomU
    TomU23-Emerald IVAuthor
    Nov 18, 2014 3:14 AM UTC
    Wow, why didn’t I think of that. Works great! Thanks!
    Tom U.
