TomU
Nov 17, 2014 11:11 PM UTC
Assign double quote character to a string parameter
Does anyone know of a way to assign a double quote to a string parameter via relations? I can manually create a new parameter and add a double quote to it, but not programmatically.
My current workaround is to manually create a parameter with a value of " and then use this parameter any time I need a double quote character.
DBL_QUOTE = " (manually created – doesn’t work in a relation)
STRING_PARAM = DBL_QUOTE + "BLAH BLAH BLAH" + DBL_QUOTE
Yes, I NEED the double quote in the final string. The ASCII value (34) is critical.
Thanks!
Tom U.
TomU
TomUAnswer
Nov 18, 2014 2:16 AM UTC
Answer, use single quotes around the double quote character.
STRING_PARAM = '"' + "BLAH BLAH BLAH" + '"'
Thanks to Don Anderson over at the PTCUser list for the answer.
TomU
TomU23-Emerald IVAuthorAnswer
