Sep 27, 2016 5:11 PM UTC
AutobuildZ
I came across this term on the internet and am trying to learn more about it.  I am using Wildfire 5.0 and would like to activate it if possible.
    Sep 27, 2016 6:34 PM UTC
    CONFIG option
    autobuildz_enable <yes>
    Sep 27, 2016 6:57 PM UTC
    I have to admit here that I am basically self taught on pro/e.  I have done very few modifications to the standard setup.  I opened pro/e went to tools, options, but am not seeing what I was expecting per above.  I am probably in the wrong place.  Can you help me further with more detail of where I need to make the change I would appreciate it.
    Sep 27, 2016 7:03 PM UTC
    I forget, but it may be a hidden config option (in fact, I'm sure of the availability in WF5)
    Close your session of PRO/E
    Open your CONFIG.PRO file in a text editor
    Type autobuildz_enabled yes
    Save and Close the CONFIG
    Launch PRO/E
    One method to verify is if there is a std.out in the start in directory, open it (text editor) and see if there are any messages related to autobuildz
