autocad file into sketcher
I am trying to use an Autocad file in sketcher.
The Acad file has mothing in it except lines.
When I am in sketcher I SKETCH/DATA FROM FILE/FILE SYSTEM then navigate to the folder where the acad file is located.
I keep getting a "INVALID DWG FILE" error from sketcher.
What am I doing wrong?
Wildfire 4.0 M100
    Resolution to my problem:
    I tried exporting the Autocad as 2007, 2004, 2000, &R14dwg with no success.
    ProE sketcher doesn't give me the option for dxf. Only drw, igsiges,dwg & ai.
    My solution was to import the Autocad drawing into a ProE drawing then import the ProE drawing into sketcher.
    A round about way of doing things but it worked.
    Thanks to everyone who responded!
    In Reply to Herb Spaulding:
    When I am in sketcher I SKETCHDATA FROM FILEFILE SYSTEM then navigate to the folder where the acad file is located.
    Wildfire 4.0 M100
