Aug 13, 2015 7:23 PM UTC
Automatically suppress multiple features at once with a rule
Can I automatically suppress multiple features at one time within Creo? For example, can I define a rule that says to suppress all holes with a diameter of 6mm or less?
    Aug 13, 2015 10:27 PM UTC
    Pretty sure you can do that through Pro/Program (Program). An IF THEN ELSE statement(s) should get you the results you want.
    Aug 13, 2015 10:47 PM UTC
    Explore the search tool.
    For example:
    You can create a search with two rules, the first select all the hole features like shown above:
    the second rule select the ones that have the pretended dimension:
    You can save this query too for later use.
    Explore a little this tool to see how powerful it can be.
    Another option is to create a layer with the previous rules, then you just have click on the layer, "select items" and "supress".
    I found recently that is possible to copy layers from one model to another, this is really handy because you can have a model with all these layers with associative filters and just copy paste it to another.
    Jose
    TomU
    Aug 13, 2015 11:01 PM UTC
    Jose Costa‌,
    Can you please confirm that "AND" works correctly is this specific case?  In Creo 3 M050 it seems to be ignoring the "AND" and treating the compound query like "OR".
    Aug 14, 2015 3:04 PM UTC
    Yes, the "and" condition is working. The problem is that this filter selects all kind of dimensions, not just diameters.
    Creo 2.0 M110
    José
    TomU
    Aug 13, 2015 10:58 PM UTC
    Not easily, and not without advance planning.  If this is a model that you have full control over and want to build automation into, then yes.  If you simply want to open anyone's model, locate fasteners by size, and create a rule to suppress, then no.
    • Pro-Program works fine to suppress and resume things, but you have to manually create the logical statements to do so in advance.
    • Rules can be created to find certain types of objects, but to the best of my knowledge Pro-Program cannot make decisions based on them.
    Here are the steps to automate with Pro-Program:
    1. Create a parameter to represent your minimum hole size.  ex. MIN_SIZE
    2. Edit Pro-Program
      1. Add an IF statement before each hole feature based on the parameter and the hole's dimension.
      2. Add an END IF after each ADD/END ADD block.
      3. Save the Program
    3. Control which holes are suppressed by editing the value of MIN_SIZE (and regenerating).
    Example (d18 is the hole diameter):
    IF D18 > MIN_SIZE
        ADD FEATURE (XXX)
       END ADD
    END IF
