Auxiliary applications loading
Hi There Fellow Pro Engineer users I would like to know if there is a way to get ProE to Automaticaly load a Auxiliary program when I open it. Or if ProE can Automatically execute a single mapkey every time Proe is Loaded. Thanks for your help on this
    Hendrik, A couple of possibilities: 1. Probably could be done with Pro/Toolkit, don't know for sure. 2. An easier solution might be to use a Trail File for a short session that makes the external call or mapkey call you want to make. See a post in this forum from Andrew Deighton, Mar 22, 2007, 6:41 pm, his response to a topic titled menu_def.pro, ... David
    Hendrik, See also: http://www.proesite.com/newframe.htm?/nttips.htm on starting external programs from within Pro/E (from another Andrew Deighton post, topic Mapkeys, Feb 20, 2007, 4:39 pm). David
    Thanks Guys Will give it a tryand see wat I can do, at the moment I just created a mapkey F2 that loads it every time you press it when proe starts.
