I think the big difference is--now that I remember back a year from when we switched from 2001--is that you have to actually be moving the dimension to flip the arrows. In Rev. 2001, you could actually flip the arrows when the dimension was just highlighted--you didn't have to be moving it.
I think the slight difference in WF2 is that you have to hold down the LMB while dragging the dim and simultaneously click the RMB to flip the arrows. It feels awkward. I don't remember exactly how it worked in 2001, but I think in 2001 you don't need to hold down the LMB to drag (I could be wrong though).
It works a little differently now. It's kinda tricky because in WF2, you have to hold down the LMB while dragging the dim and simultaneously click the RMB to flip the arrows. It feels awkward. In 2001, you don't need to hold down the LMB to drag the dim.
Sorry if you get this more than once, but I'm having trouble with my posts not showing up.
Chris
Chris D. Romero Advanced Nuclear Technology * E-mail: - N-2 Design Section * Phone: 505.667.3141 Los Alamos National Laboratory, MS B-228 * Fax: 505.665.9849 Los Alamos, New Mexico 87545 * Pager: 505.996.0596 www.lanl.gov
This discussion seems odd. It works for me. Here's my details:
1. In a drawing... 2. select a dimension with left mouse button. 3. left CLICK AND HOLD on the dimension, you should be able to move the dimension. 4. while HOLDING the left click from step 3, right click (click and release) should flip the arrows
To sum up, you are holding down the LMB while moving the dimension and you should be able to right click to flip arrows.
I can move the dimension and flip the arrows at the same time. As mentioned before, this is likely a problem with how the clicks are held and released (mouse sensitivity or something like that)
LMB to highlight the dimension, release LMB. Move the cursor over the dimension number itself and when you see four arrows, RMB and hold for ~1 second - the menu will then pop up with 'Flip Arrows'.
I have both 2001 and WF130 on my machine. The difference is in 2001 the dimension has to be moving for the arrow to flio. I wrote a mapkey because I did not like moving dims around that were lined up.
mapkey fa @MAPKEY_LABELFLIP ARROWS;#FLIP ARROWS;@PAUSE_FOR_SCREEN_PICK;
In WF2 it is better. You LMB click on the dim then RMB click to flip then back to LMB to accept. Dimension does not have to move, That is good! You do not have to hold down the LMB and RMB at same time.
It's actually a little different in WF2. You see you have to hold down the left mouse button and click the right button while the right is still down....sorry I couldn't resist!
Wow! Using WF2 is quite difficult when it comes to flipping arrows. You have to hold the LMB and click the RMB 50 times before the arrows will flip. At least that's how many times people have answered this same question! 🙂
Scott
Windchill Satisfaction Survey
Help shape the future of Windchill. Take our 5-minute survey and share your feedback.
