bat file
Pro E users,
What is the file " proe1.psf " in the proe bat file?
Brad
WF 3
    Brad,
    The .psf file is the preferences file that is used to set environment variables for the launch of Pro/E. These are typically set during installation of the software. You can also edit the .psf manually to add/change environment variables as necessary.
    In Reply to Brad Mozley:
    Pro E users,
    Brad
    WF 3
    Sean Sullivan
    Velcon Filters LLC
    CAD Administrator / Product Development Engineer
