Beam Releases in Mechanica
Hi
I have used curves from ProE to describe some beams into a solid and want
to release the rotational degrees of freedom
Is there anyway I could do this without deleting the curves and describing
the beams inside mechanica?
Ken T
    you should use point-point reference to build beam
    if you use curve,you can not apply releases in mechanica
