Jan 6, 2014 9:48 PM UTC
Bending customised tubes in Creo 2.0
Hi all,
I'm designing a Formula Student chassis as a final year project to be used at next years event. However, I have come across a problem. Using a discussion I found on here from April 2013, I have managed to add the tubing as per the event rules, but it said that it was only for straight tubes. Is there any way of bending customised tubes to be used for the roll hoops, or is it a matter of just using the closest existing tube?
Thanks a lot,
Tim
    Jan 6, 2014 10:13 PM UTC
    The best way to do this is to use AFX (Advanced Framework Extention) if you have a license.
    Jan 6, 2014 10:23 PM UTC
    That's what I'm using; the framework section of the AFX/EFX
    Jan 6, 2014 10:50 PM UTC
    You will need to create your datum sketch with the curve in it.
