Aug 8, 2012 12:17 PM UTC
Bending moments of a cut in a PRO/MECHANICA (Wildfire4) 3D model
Is it possible to calculate the bending moments and other properties of a cut from a solid model of a mechanica calculation?
    Aug 14, 2012 7:38 AM UTC
    Helena,
    I'm not sure what you mean by "bending moments of a cut".
    Can you explain your requirements in a little more detail, maybe with some pictures?
    Sep 21, 2012 9:14 AM UTC
    What I mean is: Is it possible to integrate the stresses of a cut (any cut) of a structure, so that you achieve the resultant forces and moments of the cut?
    Sep 24, 2012 8:51 AM UTC
    I don't think this is possible to do exactly as you describe.
    However, it might be possible to use Info -> Review Total Load, perhaps with a coordinate system created at the point of interest.
    It may also be possible by creating your cut and applying only the loads on one side, and creating a Simulation Measure on the cut surface - but I'm not sure whether a measure type exists that will give you bending and shear forces.
