bending table
I want to do a new bending table. with somo data that i have
    For bend data you should design your part in sheet metal first.Then open your DWG and following the following steps: Click on Intpkg> tables > bend data> If your sheet metal part have instance in it.It pops up your sheet metal part # and instace name (e.gxxx_fl01) Select part not instance and the just follow the instruction which are show under your DWG.
