Apr 7, 2015 6:44 PM UTC
Bevel Gears not turning at the same speed.
Hello All,
Another question. I have setup two bevel gears I can get them to run, and also in the right direction. However I cannot get them to go at the same speed without applying a servo motor to both gears. Is there some way around this to only apply one servo motor, or are two servos a must? Thanks in advance for the help.
    Apr 8, 2015 2:47 AM UTC
    Yep, use the generic gear connection.
    See attached (Creo 2.0 full version)
    Apr 8, 2015 2:34 AM UTC
    Mechanism may be using the reference axes to determine the ratio. You need to set this to user ratio. Bevel gears act a little different behind the scenes than spur gears. With spur gears, I can set whatever ration I want under a user definition.
    fphelps1-VisitorAuthor
    Apr 8, 2015 2:39 AM UTC
    Thanks for the reply Antonius. Could you please explain where and how I set it to the "user ratio". Thanks.
    Apr 8, 2015 3:29 AM UTC
    Thank you sir!
