Build comparison?
Proe Users,
Is there a web page or document that PTC lists the changes that occur from
build to build? If so where do I get it?
Thank you
Ryan Crisp
Mechanical Engineer
501 Morrison Rd.
Columbus, OH 43230
P: (614)337-9979
F: (614)337-9499
www.prioritydesigns.com
    Used to be the Update Advisor, but that is down for work until mid 2008. I would also like to see which SPRs are addressed - Intralink and PDMLink have a delivered this with each build for a long time now. Made it easier to determine to see if the build was worth reviewing and testing. It was still not 100% complete as often there were more fixes, functions and of course some new bugs, but itisa start.
    Jeff Zemsky
    It's been down for a long time, hopefully that means a thorough
    overhaul. It frequently gave confusing numbers. Things like old build
    had 100 open issues, new build has 10 new, 20 fixed and a total of 96
    open issues. Hmm ... 100 + 10 - 20 = 90, not 96. PTC math, I guess.
    Doug Schaefer
    Ryan,
    There are documents available that describe new features from release to release. Typically called Release Notes. These can be found on the main support page, on the left side, under downloads, Reference Documents.
