Chris3
May 10, 2016 7:16 PM UTC
Can a mapkey delete itself?
I tried recording it and nothing got recorded so I am guessing not. Has anyone played a trail file or otherwise deleted a mapkey?
Currently I am loading back in a blank mapkey over the top of the old mapkey which effectively deletes it. It still leaves it in the list of mapkeys though.
    May 10, 2016 11:01 PM UTC
    I think it can, look at this example:
    mapkey $F6 ~ Command `ProCmdUtilMacros`;\
    ~ Select `mapkey_main` `list_mapkeys` 1 `$F6`;\
    ~ Activate `mapkey_main` `DeleteButton`;\
    ~ Activate `mapkey_main` `CloseButton`;
    It opens macro dialog, selects the desired mapkey, deletes it and close dialog box.
    Just replace  $F6 with your own mapkey name in line 1 and 2.
    Jose.
    kdirth
    May 10, 2016 9:58 PM UTC
    You should be able to delete a mapkey in the dialog box.  Remember, you must then save your mapkeys to keep the change.
    You can also delete lines out of your config.pro file.
    Jose.
    2-Explorer
    May 11, 2016 2:16 AM UTC
    Did you pull that from the trail file or coerce the mapkey to record it?
    Asking for a friend.
    May 11, 2016 7:20 AM UTC
    Yes, I did the cheating, I copied it from the trailfile.
