can anybody convert brocken view to previous view
hi i coneverted a view to brocken view i want to break in horizontal direction but i got in vertical direction i want to modify how can i?
    hi there, change it back to a full view then try to make it right regards, vb
    You can select vertical or horizontal only if the view is general view. But a I think broken view cannot be removed. only thing you can do is delete that view and place a new view.
