Aug 25, 2015 6:40 PM UTC
Can I save file in Creo 3.0 to the version Creo 2.0?
Aug 26, 2015 7:42 AM UTC
Leandro,
see also compatible of CRO 2.0 with Wildfire 4.0
Martin Hanak
Mahesh_Sharma
22-Sapphire I
Aug 25, 2015 7:03 PM UTC
Not a direct option, GCRI can be used for the same.
Refer earlier post Re: 3.0 to 2.0
lbristot1-VisitorAuthor
Aug 25, 2015 7:28 PM UTC
What did you mean with "GCRI" ?
Mahesh_Sharma
22-Sapphire I
Aug 25, 2015 8:20 PM UTC
GCRI > GRANITE-Based Cross-Release Interoperability
Creo files are not backward compatible, files created in higher versions cannot save to open in older versions.
As in earlier post, there is a DLL which can use to open higher version file in lower version. File open in lower version will hold all features, however features from higher cannot modify. New features can create in lower version.
Mahesh_Sharma
22-Sapphire I
Sep 4, 2015 4:14 PM UTC
Leandro,
Does any of the earlier replies help you to import files in earlier version?
Sep 4, 2015 5:42 PM UTC
Yes Mahesh Sharma. Thanks for you attention.
Mahesh_Sharma
22-Sapphire I
Sep 4, 2015 5:50 PM UTC
Leandro,
You may mark appropriate replay as correct answer for the post.
