Can Pro/E report basic units shown modeltree column
Is there a way to have Pro/E report the pro_unit_length and
pro_unit_mass in the modeltree
We've received model from all over the world. (imperial & SI)
during conversion to SI things got messed up with densitie units
This resulted in way to big masses
I'm looking for quick way to check which of the parts have wrong units
Hope you help me
    Hopefully this helps. This is a screen shot of the model tree i use.
    The weights are relation driven from the mass(this is in our start parts). It gives me a quick check to see when mass is incorrectly assigned. You will find mp_density undertree/column display/type/mass properties params
    Steve
    WF-2 M080 FlexC
    Win XP SP-2
    Dell PWS 690 3GB Ram
    Nvidia Quadro FX4600
