Nov 25, 2008 10:25 AM UTC
Chamfer
Hi friends, Some system allowing chamfer 0.6 mm (minimum) and other system allowing 1 mm (minimum) why? Any one can know which variable we need to change? Friend senthilnathan.G
    Nov 25, 2008 6:18 PM UTC
    May be you need to set up accuracy smaller(Edit/Setup/Accuracy).
