Chamfer dim - Summary
- 0 replies
- 371 views
- Translate All
Apparently, for WF3, the ANSI standard has changed to the same as the
ISO and JIS standard format for the chamfer dimensioning technique. It
doesn't matter which format you select in the detail file, it will now
only allow the witness line to appear and extend out the way I showed it
in the picture. I can't say it's wrong, but I prefer the old method
that pivots about the chamfer. Since we don't follow any standard too
strictly, I would use the old method if I could. I guess I have no
choice now. Thanx for the help.
Here's the PTC link for the 'upgrade'...
