Nov 16, 2015 7:07 AM UTC
change item location in table
how can i change item location in table? i would like to change the item 2 to item 3,and change item 3 to 2
thanks
pls reference the blow table .
    ldrutelAnswer
    Nov 16, 2015 9:30 AM UTC
    If this is a repetition table, You can Fix item
    1) Select Repetition table tab
    2) Select Fix item and select your repetition table
    Now you can fix each item you want to do
    ldrutel1-VisitorAnswer
    ychen-41-VisitorAuthor
    Nov 17, 2015 1:14 AM UTC
    thanks the first !
    let me try .......
    Nov 17, 2015 4:57 AM UTC
    thanks laurent
    I have changed the item location use your solution!
    select the repeat table,the system says:Can not fix index due to symbol asm.mbr.cparam
    SEQ NO.properties &asm.mbr.cparam.seq_no.  so i need modify this SEQ NO properties(delete "&" temporary)
    after change the SEQ NO . i can select the repeat table fix the item .
