May 31, 2012 6:30 PM UTC
Change K factor system wide
Is there a way to change the K factor system wide?
I know that I can change it with edit definition on each bend, but I'd like to change it system wide.
We work with metal steel plate, usually thicker than 15.7mm, and the designated K factor (0.318) is not correct, according to my supervisor.
Please let me know and thank you!
    Jun 1, 2012 6:27 AM UTC
    You could use a sheetmetal start part with the appropriate k-factor or bend table assigned.
    Reinhard
    .. and you should use start parts as steel and aluminium have different k-factors.
    KrisR1-VisitorAuthor
    Jun 1, 2012 11:13 AM UTC
    How do I set the K factor before modeling? As of now I can only see to add the option via edit definition on an actual bend.
    Jun 1, 2012 2:55 PM UTC
    Creo 1
    #file #prepare #model properties #bend allowance
