Aug 4, 2014 4:04 PM UTC
Change Text Color
Is it possible to change the text color within a text string in a table cell?
Example:
DIMENSIONA = WHEN LOAD = 5 LBS.
    Aug 7, 2014 12:21 PM UTC
    Gary,
    Sorry to see this a few days late....
    Unfortunately we do not have the ability to affect change to one piece of text string within a single field. However, not all is lost...as there is always an answer if you keep digging. Or are old and crusty like me from the early days of Pro wherethere weretons of behind the scenes tricks to get the job done.I have attached a drawing with two tables. The second is a copy of the first and isthe "end run" version visually depicting what it is you want to do. A before and after the hocus pocus, if you will.I have placed text in the first cell that overlaps the secondcolumn and I have simply "blanked" the column lines either side of the 5.25. You get the visual you want.
    Sincerely,
    Old Crusty Bustedness
    In Reply to Gary Linscheid:
    Example:
    Aug 7, 2014 2:26 PM UTC
    Sorry Everyone, I had an assemblyin session that got tagged to the drawing. This attachment is free and clear of External Refs.
