Changing the dashboard position in wildfire 5
Hi everybody,
Please can anybody say how to change the DASHBOARD POSITION IN PRO/E WILDFIRE 5??
I have tried the following steps TOOLS - CUSTOMIZE WINDOW - OPTIONS TAB but I can't find any tab or icon to change the DASHBOARD POSITION..
If anybody know the solution for my question please reply......
    You can't move it. One of the changes that was made was to fix its location at the top. I've heard it was due to a change in workflow to use the ribbon interface.
    That's just dumb. Another case of progammers telling the users what's best for them.
    Yep. I used to have it on the bottom. It's taken me a month to get used to it. Clearly I was doing it wrong before.
    Yes, you cannot adjust it anymore in wf5.0.
    Sure would be nice to be able to "tear" this toolbar away so I can place it on a second monitor, should be universal for all toolbars
    IMHO,
    Brian
    Sounds like you just need bigger monitors. I just wish the first Pro/E window would open maximized instead of an inch from the right side of the screen.
    I like the dashboard at the top, the only complaint is that the drop down menus cover the model tree, so when you are trying to place something in an assembly you cannot click the datums at the top of the model tree with the placement dropdown open.
    Having the ribbon makes this small inconvenience worthwhile. Just waiting for the rest of Pro/E to catch up.
