Checkin problem
Toolkiters,
Does anyone know how to do a programmatical checkin, only submitting modified
objects? I am having a problem removing objects from checkin that are not
modified. I don't know how to use the functions
PDMPISetCurrWSPIVMardedForCheckIn and PDMWSPIVSetHoldFromSubmission or any
other variation therein. Can anyone tell me the proper procedure on how to do
a checkin because the documentation sucks!
Patrick Williams
Application Engineer
Steelcase, Inc.
    Thanks for the response. I did find one thing peculiar about your suggestions
    though. You go through and mark each object to be checked in if it's
    modified. I ran through all of my objects checking the "marked for checkin"
    flag and they were all set. Are you sure that the objects in your case aren't
    already marked for checkin?
    Patrick Williams
    Steelcase, Inc.
