Checking assm
I'm trying to get an assm in to cfdesign and it keeps coming up invalid model, is there a way in Pro E to check the model though and see if there are collision or anything like that? Thanks for you time
    I'm sure Mechanism and Animation have collision check capabilities, but then that means you have to automate your assembly. There are options like that under the Analysis menue in the Standard application.
