CL FILE EDIT
I want to remove specific moves of the tool in a sequense. How can be done. Any help wil be apriciated. Thanks
    You should be able to do this in the customize menu. Without more detail this is the best I can give you.
    I want to remove specific XYZ moves without to use the edit option under the CL DATA menu, this option lets you delete lines from the cl file but dont show the toolpath lace. The ideal way would be from the sequense menu PLAY PATH ----> SCREEN PLAY which is possible to see the cl file and position the tool exatly on the move you want but do not let you delete any lines. The CUSTOMIZE MENU allows you to add extra CL commands.
    Ok, try going into customize, pick the follow cut - redefine - click split add and pick the start point of what you want to delete on your tool path - click add again and pick the end point of what you want to delete on your tool path. You will now have 3 follow cuts, pick the one in the middle and delete it. You could also add approch and exit moves to it at this point. I hope this helps. Wes
